Setting arcpy.env tolerance and resolution in standalone script
2984
8
06-05-2020 11:49 AM
MarvisKisakye1
I have a template file from which I am retrieving tolerance and resolution settings as in the code below. Using arcpy.AddMessage, I am able to confirm that the settings were retrieved from the template file and applied. I then run FeatureClassToFeatureClass in a bid to have the newly set tolerance and resolution values applied to the output feature class. Unfortunately, these settings are not applied to the output file. When I run this same code in the python window, the settings are applied as expected. I am using ArcGIS Pro 2.5.1. Dan Patterson
templateFile=arcpy.GetParameterAsText(0)
if templateFile != "":
    sr_object=arcpy.Describe(templateFile).spatialreference
    arcpy.env.MTolerance=sr_object.MTolerance
    arcpy.env.MResolution=sr_object.MResolution
    arcpy.env.XYTolerance="{0} {1}".format(sr_object.XYTolerance,sr_object.linearUnitName)
    arcpy.env.XYResolution="{0} {1}".format(sr_object.XYResolution,sr_object.linearUnitName)
arcpy.AddMessage(arcpy.env.MTolerance)
arcpy.AddMessage(arcpy.env.MResolution)
arcpy.AddMessage(arcpy.env.XYTolerance)
arcpy.AddMessage(arcpy.env.XYResolution)
arcpy.FeatureClassToFeatureClass_conversion("Mylayer","//Path//to//gdb", "OutLayer")‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
DavidPike
MVP Notable Contributor
I know it makes little sense but it may be an arcpy quirk, have you tried something like:
MTolerance = sr_object.MTolerance
arcpy.env.MTolerance = MTolerance
arcpy.FeatureClassToFeatureClass_conversion()
MarvisKisakye1
I tried setting the environments as you did above but they are still not applied to the output files.
DavidPike
can you humour me and show the print/add message results please
MarvisKisakye1
Here are the AddMessage results:
6.213699494949262e-07
6.213699494949262e-08
0.003280839895013 Foot
0.0010763910416709318 Foot
But when I look at the properties of the output, it has different values from above.
DavidPike
I would say that "0.003280839895013 Foot" etc. is being passed as an incorrect variable which is ignored by the environment.
"0.003280839895013 Feet" should be passed?
MarvisKisakye1
I also tried running it with the code below to ensure that the linear units show up as feet instead of foot.
    units=""
    if sr_object.linearUnitCode==9002:
	units="Feet"
    else:
	units=sr_object.linearUnitName
    arcpy.env.XYTolerance="{0} {1}".format(sr_object.XYTolerance,units)
    arcpy.env.XYResolution="{0} {1}".format(sr_object.XYResolution,units)
The AddMessage results then were:
0.0010763910416709318 Feet‍‍‍‍
This didn't make a difference in the behaviour of the script. It's still pretty erratic. It doesn't work 99% of the time and then it will randomly work out of the blue with no changes to the code.
DavidPike
Are you writing to a feature dataset? I guess that would ignore any environments to preserve topology etc?
MarvisKisakye1
No. I am writing to a geodatabase in ArcGIS Pro.
