ERROR 999999: Error executing function. Workspace or data source is read only. Failed to execute (PackageMap).
1222
06-02-2020 09:19 AM
JulieHines1
I am trying to package a map and I keep getting this error.
Tags (1)
DanPatterson
MVP Esteemed Contributor
Some details Julie Hines‌about the details of the map you are trying to package.
Some first tries...
Did you save, close and restart?
What is the actual workspace path? (local, network etc)
What is the data source path? (same as above)
... sort of retired...
JulieHines1
The map I am trying to package contains only local data.
I did save and close the project
Network for both
DanPatterson
What about the last 2 questions?  You can anonymize the paths without changing the first letter of each subfolder or the file name if needed
