max value of a field as variable
1735
06-02-2020 02:50 AM
AlfonsZitterbacke
With the following script I was able to determine the maximum values of a column [POINT_Z] for certain groups from [ID_1].
    #creating a list ->"mast_value" with unique values of field [ID_1]
    with arcpy.da.SearchCursor(inLAS[:-4] + '_POLE_POINTS.SHP','ID_1') as max_cursor:
        for row in max_cursor:
            mast_value = sorted({row[0] for row in max_cursor})
    #iterate through the list to find highest value in field [pointz], but only in features which have the value of the element of the list "mast_value"
    field = "ID_1"
    for mast in mast_value:
        abfrage = field + " = " + str(mast)
        with arcpy.da.SearchCursor(inLAS[:-4] + '_POLE_POINTS.SHP',('POINT_Z', 'FID'), where_clause=abfrage) as mast_cursor:
            mylist = []
            for row1 in mast_cursor:
                #print('ID ' + str(mast) + u': max altitude ' + str(max(mast_cursor)))
                print(str(max(mast_cursor)))‍‍‍‍‍‍‍‍‍‍‍‍‍‍
With the output I can display the results. A manual check showed that the result is correct.
ID 1: max altitude (477.56, 5997)
ID 7: max altitude (523.27, 3401)
ID 16: max altitude (495.69, 3203)
ID 38: max altitude (495.69, 5574)
ID 39: max altitude (470.16, 5986)
ID 44: max altitude (503.93, 4713)
ID 63: max altitude (503.97, 4185)
ID 73: max altitude (463.67, 4205)
ID 75: max altitude (518.59, 2880)
ID 77: max altitude (463.63, 5877)
ID 79: max altitude (485.91, 5594)
ID 87: max altitude (482.06, 853)
ID 88: max altitude (475.2, 1836)
ID 91: max altitude (492.0, 1074)
ID 97: max altitude (468.77, 1323)
ID 98: max altitude (462.52, 1546)
ID 99: max altitude (463.81, 1294)‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
To continue working (selection), I need the corrosponding value [FID] (second value in the brackets) of the maximum value of [POINT_Z] as a variable. My attempt to write the result into a variable
myMastList = str(max(mast_cursor))
fails with an error message.
File "E:\Documents\LAS\Las_Wire.py", line 264, in masten myMastList = str(max(mast_cursor))ValueError: max() arg is an empty sequence ‍
How can I write the value of [FID] (second value in the brackets in the output) from the highest value of [POINT_Z] (or both [FID] and [POINT_Z]) into a variable?
Tags (1)
DavidPike
MVP Notable Contributor
I t's very hard to follow your code in that format.
can you populate a list in
mylist = []
mylist.append…..
AlfonsZitterbacke
Hi David,
sorry for the missing syntax highlighting. I corrected my initial post, so it should be less confusing.
Furthermore I tried your sugestion, but unfortuntaly I got the same error message:
 field = "ID_1"
         mylist = []
             mylist.append(max(mast_cursor))
             print(str(max(mast_cursor)))‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
DavidPike
I'm not entirely sure of what's going on, why the dictionary comprehension in the first cursor?
Also I don't see the need for the SQL filter (where clause), can you not evaluate it for each row - if ID=x... row.append
Also think you can instantiate the cursor once, i.e. put it above for mast in mast_value: then call max_cursor.reset()
