How to append two FC one with additional fields in Python
780
06-01-2020 12:13 PM
JoseSanchez
Good afternoon,
I am writing a scripts that  appends records  in several FC and some of them have additional fields because the schema was  modified.
Can I use this kind of Python script with "NO_TEST"  when  I copy the same FC but the new version has more fields than the old one ?
taget_layer is the new version of source_layer but in several cases it has additional fields.
fieldmappings = arcpy.FieldMappings()
#Like when you manually choose a layer in the toolbox and it adds the fields to grid
fieldmappings.addTable(target_layer)
fieldmappings.addTable(append_layer)
arcpy.Append_management(append_laye, target_layer, 'NO_TEST', ffieldmappings)
DanPatterson
MVP Esteemed Contributor
from... Append—Data Management toolbox | Documentation
clear ... I think
  • If Use the Field Map to reconcile schema differences is chosen (schema_type = "NO_TEST" in Python), the input dataset schema (field definitions) do not have to match the target dataset. However, any fields from the input datasets that do not match the fields of the target dataset will not be mapped to the target dataset unless the mapping is explicitly set in the Field Map parameter.
  • Because the input datasets' data is written to an existing target dataset that has a predefined schema (field definitions), the Field Map parameter does not allow for fields to be added or removed from the target dataset.
So I would give it a try on copies to confirm
... sort of retired...
