Embedded Content Option is Missing
1373
05-25-2020 06:50 PM
Dionisiobattad
Hi All,
I would like to embed a weather web page on my dashboard. The documentation says I should use embedded content. My problem is I can not see the embedded content option. We are using Portal for ArcGIS 10.6.
Also, I would like to configure my map to zoom in at a few bookmarks I made based on a specified time interval and sequence.
Any help is much appreciated.
Thanks.
Below is what I can only see:
DerekLaw
Esri Esteemed Contributor
Hi Dionisio,
The Embedded Content element was not part of the first ArcGIS Dashboards release - which is the version included with ArcGIS Enterprise 10.6. Sorry. I believe you will have to upgrade to ArcGIS Enterprise 10.7 or later to have that functionality in ArcGIS Dashboards in Portal for ArcGIS. Or simply use ArcGIS Dashboards in ArcGIS Online.
This functionality is available in the Map element. You can "turn on" support for spatial bookmarks in the Map element configuration panel.
Map element—ArcGIS Dashboards | Documentation
Hope this helps,
DerekLaw
Hi Dionisio,
Hope this helps,
Dionisiobattad
Thanks very much, Derek.
