How to display images in web layer attributes
529
05-24-2020 05:26 PM
AudurBlondal
Hello, I set up a sidecar that displays a web layer. When viewed in an AGOL map, the web layer displays images in the attributes, as it is set up to do. But when displayed in the sidecar, the text "<div><p><span/></p></div>" shows up instead of an image.
OwenGeo
Esri Notable Contributor
 Hi -- Can you share your story, map, and/or layer so we can take a look? If you're not able to share your story publicly, please contact Esri Tech Support and they will be able to help you troubleshoot this issue.
Owen Evans
