Fill class FeatureServiceTable with JSON Data?
1159
05-22-2020 02:54 AM
KengueDonald
Hi!
Please i'm new to Arcgis and i'm trying to use the following method:
mServiceFeatureTable = new ServiceFeatureTable(data);
I remark that this class use in parameter an URL, but me i just have data in a JSON file. So i would like to know how can i use it with a JSON file, otherwise if it is impossible is it a way to transform my data into urls for using it? if yes could you give me a sample demonstration or the steps to follow?
Nicholas-Furness
Hi.
You could do one of 2 things:
1. If it's GeoJSON you could upload it to create a new feature service in ArcGIS Online. See this document. This will give you a feature service with a single layer in it. That layer will have a URL that you can use with a ServiceFeatureTable (as above).
2. You could parse the JSON to create a FeatureCollection. See this tutorial.
In short, you can definitely parse it or import it, depending on the data format.
Hope that helps.
Nicholas-Furness
Hi.
Hope that helps.
KengueDonald
Thank you very much, it was very helpful. Now I'm done.
Thank
