Client Side FeatureLayer Fails Points with over 60k
4813
05-20-2020 06:22 PM
SangHyouk_Oum
I am trying to map over 100k points using Client-side featureLayer. It works very well but fails if graphics are over 60k (Actually start failing from 62432). I also tested with featureReduction enabled but still the same.
You can test by changing the total at: https://jsfiddle.net/aqxk15zu/
Any idea?
KenBuja
MVP Esteemed Contributor
It looks like it's both memory and browser dependent. In Chrome (81.0), I would get a "script error" message above 125380 points. In Firefox (76.0), I would run out of memory somewhere between 400000 and 450000 points. If I put 500000 points, I got a "RangeError: too many arguments provided for a function call" error
SangHyouk_Oum
Thanks for testing and reply! I just tested on different browsers and got different numbers. Seems like I will have to cluster data by myself before putting into featureLayer to make sure it does not fail.
mgeorge
Hi Sang Hyouk Oum
Thanks for bringing this to our attention. Definitely the underlying engine should be able to handle more than this number of points, I'll take a look and see what's going on.
