Iterator not working
5414
05-20-2020 08:23 AM
by Anonymous User
Not applicable
I am currently attempting a Least Cost Path analysis, specifically, a "From everywhere to everywhere model".
Cost raster = Slope_Raster
Surface raster = 0 value extracted_DEM
Vertical Factor: Tobler Away
To achieve thus multi-path approach, I made my destination (which, according to this model, will also become origins) points through the Fishnet tool, settling for a 25kmx25km grid. I then put this fishnet through "Split by attributes" to acquire individual points that I could run separately through the Path distance tool. I then merged these points so that I could run them collectively through "Iterate Feature Selection" in Model Builder.
It is at this stage that I encounter a problem. When the Model runs, it only iterates through the first three points of the merged points. I have tried selecting different fields, and I have even tried to achieve an iteration through a separate tool ("Iterate feature class"). No matter what variation I try, the same issues arises; the model only create paths for the first three points out of the entire 83 point feature.
I am at a loss as to what to do, and cannot seem to find what is causing this error.
Thank you in advance.
P.S. I know this method of achieving multiple pathways is possible as I used the same model building technique in ArcMap 10.7.1 and it worked (However the processing was incredibly slow).
curtvprice
Unclear to me why it would stop after three iterations.
One thing I noticed though, I suggest you put the iterator inside a submodel so you don't run the path distance over and over again on every iteration. Iterators re-run all tools in the model  (unless you somehow prevent this with a precondition logic - a sub model is an easier way to control that).
If you must run it every iteration (unclear), you may want to set a precondition from the output to the iterator to the path distance tool, to make sure the path distance runs after the selection is made.
JacobCurrie
I realize this is an old issue. I encountered the same problem.
Windows 11, ArcGIS Pro 3.1.2, Model Builder
Problem:
I would run a model in ModelBuilder using an Iterator that processed 5 times. Sometimes it would iterate 3 times and others it would stop part way through the 5th and final iteration.
Findings:
I noticed that my system temp files volume was massive. I also saw that my .gdb size was huge. The volumes seem to grow a lot as I worked with, adjusted, and re-ran the model.
My Solution:
-Clear the system temp files
-Compact my project .gdb
-Set the project layer cache to be deleted at the end of the session
Result:
Worked without issue afterwards.
