uploading time enabled point data to arc online
1364
05-17-2020 05:53 AM
DanielFuller
I'm making a story map for my final year project comparing how greenhouse gasses have affected greenland ice retreat
i've made a time series map showing the output of carbon dioxide of each country that scales a point located on the centroid with the assossiated carbon output.
in ArcGIS Pro it works fine, more than fine, but when i share it as a web layer the table fails to upload properly and i get this error
I did not have any errors when sharing the data through the share as web layer tab appart from error 24041 which i have been advised is not causing the issue
any guidance would be very much appreciated
DavidPike
MVP Notable Contributor
Do you have a join or relate associated with the shared layer?
DanielFuller
not as far as i know, i have a query affecting one of the columns but that is it
DavidPike
A definition query? I'd guess that could be an issue.
DanielFuller
I removed the query and reuploded as a separate web layer and the issue is still persisting
