Load Features from Spatialite database
1469
05-13-2020 12:58 PM
ViníciusCosta
Hello, I've been looking into the Feature Layer (Geodatabase) QML example and I've tried to just do the same with a sqlite spatialite database, to no avail
Is it possible to do so?
I have a spatial table with the following structure, created from SQlite:
CREATE TABLE "furos" (
"OBJECTID" integer NOT NULL PRIMARY KEY AUTOINCREMENT,
"SHAPE" MULTIPOINT,
"ID_FURO" integer NOT NULL,
"FURO_TX_NOME" text(255),
"FURO_VL_MC" text(50),
"FURO_VL_LAM_DAGUA" text(50),
"FURO_VL_PROF_FINAL" text(50),
"X_SIRGAS" text(50),
"Y_SIRGAS" text(50),
"X_CGS" text(50),
"Y_CGS" text(50),
"GUID" TEXT(255),
"DATA_IMPORTACAO" DATE
And I've tried loading the database file by basically doing the same code from the geodatabase example:
 Map {
            BasemapStreetsVector {}
            FeatureLayer {
                featureTable: gdb.geodatabaseFeatureTablesByTableName["furos"] ?
                                  gdb.geodatabaseFeatureTablesByTableName["furos"] :
                                  null
                Geodatabase {
                     path: pathName
                    onErrorChanged: errorMessage = error.message;
                onLoadStatusChanged: {
                    console.log(dataPath);
                    console.log(errorMessage);
                    if (loadStatus !== Enums.LoadStatusLoaded)
                        return;
                    mapView.setViewpointCenterAndScale(fullExtent.center, 80000);
Unfortunately, nothing happens. I receive these three errors from Qt:
Exception at 0x7ffd59bfa799, code: 0xe06d7363: C++ exception, flags=0x1 (execution cannot be continued) (first chance) in runtimecore!RT_UtilityTraversability_fromJSON
Exception at 0x7ffd59bfa799, code: 0xe06d7363: C++ exception, flags=0x1 (execution cannot be continued) (first chance) in runtimecore!ESRI_CopyProtect_GetInstallDir
Exception at 0x7ffd59bfa799, code: 0xe06d7363: C++ exception, flags=0x1 (execution cannot be continued) (first chance) in ntdll!RtlCaptureContext
Is it possible to load only geodatabases created from ArcMap or something similar? I can open these kind of files in the SQLite Browser so I thought the format was basically the same.
LucasDanzinger
Esri Frequent Contributor
We do not support the SpatialLite format. Geodatabases can be created through ArcGIS Pro's create Mobile Map Package tool (the .geodatabase will be inside the mmpk), ArcMap's Create Runtime Content tool, or various online REST endpoints/Go Offline APIs that we have (OfflineMapTask, GeodatabaseSyncTask)
LucasDanzinger
