Custom UI in Python Toolbox
1371
05-12-2020 05:46 AM
saurabhGupta7
Hi All,
I am trying to develop a Table with 3 columns as input parameter. The second column of table consist of drop down list where user can select from pre-configured list. I have tried using ValueTable but I am not able to remove the highlighted drop-down shown in image. Is there a way to remove the highlighted box while using ValueTable or any other way to achieve a clean UI.
Logic for the tool will be like:
User first select the Database> then its corresponding dataset> then the particular owner > table will display all the FC and Tables.
Any help will be highly appreciated.
Saurabh
LeandraGordon
Hi there - it would be useful if you could post the code you are using to make the tool as well as a screen shot of the tool
