Error occurred when checking the report template
929
05-06-2020 01:22 AM
IanDouglas
I have completed a form using Survey123. I haven’t been able to test it though. Whenever I upload the feature report I've made and generate a report it gives me the following error:
Status
Failed
Message
Error occurred when checking the report template. Failed to parse ${Client}. Field ${Client} does not exist or cannot be found in current parsing scope.
Before it was saying different fields had failed. I deleted those fields out of the feature report and then other fields seem to still fail. I’ve copied and pasted all of the fields from the sample template which I've attached. When generating a report using the sample template it works fine.
Any assistance would be much appriciated!
BrettStokes
Hi Ian,
Did you find the cause of this issue or a solution / workaround? If so, please share it on the forum. It may be worth revisiting now on the recently released 3.10 website, as there have been some imrovements and changes to feature reports.
Brett
