ListBrokenDataSources and TableViews
619
04-30-2020 06:53 AM
ChrisHolmes
Hello everyone,
ListBrokenDataSources returns a python list. What's the best way to determine if the item you are dealing with in the list is a TableView?
I'm using .supports('workspacePath') and .supports('dataSource') to deal with shapefiles and geodatabase feature classes.
I'm getting this error message when a TableView is found in the list:
AttributeError: 'TableView' object has no attribute 'supports'
How should I go about getting at the TableView properties to determine that it's a TableView?
Thanks!
ChrisHolmes
Here's what I came up with to identify if I'm dealing with a TableView:
brknItemType = str(type(brknItem))
splitType = brknItemType.split('.')[-1]
itemType = splitType[:-2]
ProcessMessage('itemType = {}'.format(itemType),systemUsed,'N')
This gives me:
There's probably a prettier way to do it, but this should work for my needs.
RandyBurton
I think you have the solution.  For a "prettier way", perhaps:
if 'TableView' in str(type(brknItem)):
    # do something‍‍‍‍
JoshuaBixby
MVP Esteemed Contributor
The "is" method is more canonical for checking object identity:
type(brknItem) is arcpy.mapping.TableView
One can also use isinstance():
isinstance(brknItem, arcpy.mapping.TableView)
