I manually created a public transit-enabled network dataset in ArcGIS Pro 2.5 for a city's MRT system (streets = OSM data), because there is no GTFS for the city that I am analysing available. All the analysis functions in the Network Analyst directly implemented in ArcGIS as well as the Transit Network Analysis Tools | GTFS in ArcGIS work perfectly for my network.
Now I wanted to try out the BetterBusBuffers | GTFS in ArcGIS . However, it seems to require a GTFS file to create a SQL database as input of the tools. Is there any way to use the tools with the public transit-enabled network dataset I manually created in ArcGIS Pro?
It would be a pity that after I put so much time into manually setting up the network dataset that I could not use the analysis functionality of Better Bus Buffers tools.
Best regards
Christian
