Building attribute rules in Arcade playground
958
04-22-2020 12:57 PM
by Anonymous User
Not applicable
New to ArcGIS Pro and Arcade.  I have found numerous examples of using Arcade in conjunction with a web map to create labels.  While in a web map, you simply click on "Change Style" above the table of contents and it takes you to Arcade's playground and populates a pane with the fields of the active featureclass.  Pretty slick.  I would like to do the same thing with Pro and Arcade.  I would like to build attribute rules in the playground and test them.  Is this possible?  If so, how?  I cannot find anything similar to the "Change Style" button that would establish connectivity between Pro and Arcade's playground, yet the three types of attribute rules all have their own profile in Arcade.
