Wanting to add layer to Table of Contents via Python
1074
03-29-2011 05:42 AM
StevenMenefee
I am trying to do something that I thought would be simple!  We use a number of shapefiles frequently and I'd like to create buttons within ArcMap that you click that will add a particular shapefile to the Table of Contents.
I decided I would write the code in Python, add that as a Script in Arctoolbox and somehow make a button that will look at that Script.  Anyway, the code I'm using SEEMS to be working.  However, I can't seem to see the layer within the Table of Contents.  Below is the code I'm using that I am adding a Script to (no Parameters).
import arcpy
mxd = arcpy.mapping.MapDocument("C:\\Gis\\Python\\mxd\\test2.mxd")
df = arcpy.mapping.ListDataFrames(mxd, "Layers")[0]
addLayer = arcpy.mapping.Layer("C:\\Gis\\GisMaps\\Attica\\layer.lyr")
arcpy.mapping.AddLayer(df, addLayer)
arcpy.RefreshActiveView()
arcpy.RefreshTOC()
del mxd, addLayer
Any help would be much appreciated, thanks!
StevenMenefee
That worked great, thank you!!
ArjunDongre
Adding RefreshActiveView and RefreshTOC get the the layer to stay in the mxd before saving. Weird this is not in the documentation for AddLayer.
