Filter Indicators on Dashboard by Map Selection
4979
04-16-2020 04:20 PM
by Anonymous User
Not applicable
I am working in ArcGIS Dashboards. My dashboard has a map and several indicators. I would like to filter the indicators by selecting features in the map, rather than having the indicators change based on the map's extent. Is this possible?
Another option would be to have a drop-down menu where users could select a feature which then changes the map view and indicators based on the selection.
Thanks in advance!
DerekLaw
Esri Esteemed Contributor
Hi Jennifer,
> I would like to filter the indicators by selecting features in the map, rather than having the indicators change based on the map's extent. Is this possible? And if so, how?
Yes, you can configure Layer Actions - you set this property on the Map element configuration panel.
Hope this helps,
DerekLaw
Hi Jennifer,
Hope this helps,
