No map display in QWidget
1872
6
04-15-2020 02:25 AM
NicolasDuboys
Hi
I build a very simple example from Qt Creator, without using Qml.
I test my license it seems to be OK, return 3 (Valid) and Initialize rturn true.
But nothing can be display on map (I try Raster, OpenstreetMap).
I have a flood on console with this message :
qt.network.monitor: Failed to subscribe to network connectivity events: "CoInitialize n’a pas été appelé."
qt.network.monitor: failed to start network status monitoring
Any ideas ?
Regards
LucasDanzinger
Esri Frequent Contributor
Do you have the OpenSSL libs somewhere in your path?
NicolasDuboys
Hello Lucas and thank for your answer.
It is woking now with 2 new dll : libcrypto-1_1-x64 & libssl-1_1-x64
I still have some flood in console :
But maps is visible !
v
LucasDanzinger
which version of Qt are you using? 5.12.4 or newer will require a newer version of OpenSSL - https://community.esri.com/community/developers/native-app-developers/arcgis-runtime-sdk-for-qt/blog...
On Windows those are libcrypto-1_1-x64.dll and libssl-1_1-x64.dll.
NicolasDuboys
Hi
Yes I have just modified my first answer, your are too quick
Still have some flood but maos is present
I usd qt 5.14.2.
Any ideas about the flood ?
LucasDanzinger
we see this error too. It seems to be something coming from Qt itself and we have not been able to identify any actual problems associated with the warning.
NicolasDuboys
OK great
Thank you for your help Lucas !
