Is there a simple way to count number of features returned by IMapServer3 object
1124
04-07-2020 02:21 AM
chrisweaves
Using the arcobjects SDK (10.7.1) I am simply trying to count the number of features returned by a feature service query, here is some sample code:
    IMapServer3 ms = (IMapServer3) this.mapServerDataAccess;
    // query for relevant features using spatial filter
    QueryResult queryResult = (QueryResult) ms.queryData(mapName,
        getTableDescription(mapServerInfo, layerId),
        spatialFilter, qResultOptions);
    RecordSet rs = (RecordSet) queryResult.getObject();
I can count the number of features returned by getting a cursor and iterating through the cursor items incrementing a counter along the way but this is extremely slow and when working with layers with 2+ million points this is not feasable.  Is there a way of getting the count of the number of features in the returned RecordSet?  I couldn't see anything obvious.
Appreciate your help.
KenBuja
MVP Esteemed Contributor
If you use a IRecordSet2 class, it has the Table property. You should be able to use the ITable's RowCount method.
chrisweaves
Thanks Ken, I'll give that a try!!
