Calculate prediction zone from the crime analysis solution is not giving the expected output. Instead ArcGIS pro shuts down and send report window pop up. Any Ideas why this is happening? Thanks
1398
04-04-2020 10:46 PM
deleted-user-0JRNzqbsDKst
Input Feature class has 3419 features
DanPatterson_Retired
from here
Crime Analysis | ArcGIS Solutions for Local Government
the first question is.... has it ever worked?
then, do you have the requirements?
The error is pretty serious to cause such a crash.  Did you file the report? If not, you should really contact Tech Support to get a resolution.
It has never worked even though it is my first time working with the tool. I have tried to run it using other feature classes as well but it keeps crushing. I have attached the report here.
