Runtime .net access error
3294
6
04-05-2020 10:15 AM
GrantHaynes
Hi guys,
So I'm working on an augmented reality mobile app, it's real basic, I just want to see monitoring wells in place. Anyway I am using my monitoring well dataset in AGOL and I am having trouble accessing the data, below is the C# code that is attempting to access the data.
   _portal = await ArcGISPortal.CreateAsync(baseAddress, cred);
   _envWorkingData = await PortalItem.CreateAsync(_portal, "####");
   // build a URL to the first layer in the service
   var welluri = new Uri(_envWorkingData.Url + "/1");
   // create a new service feature table referencing the service
   var wellTable = new ServiceFeatureTable(welluri);
   // create a new feature layer from the table
   await wellTable.LoadAsync(); <- Here is where the access error shows up
   if(wellTable.LoadStatus == Esri.ArcGISRuntime.LoadStatus.Loaded)
      _wellsLayer = new FeatureLayer(wellTable);
I get error #403 "You do not have permissions to access this resource or perform this operation.", even though I have a publisher level AGOL account. Any ideas?
Tags (1)
MichaelBranscomb
Esri Frequent Contributor
Try adding the credential to the Authentication Manager e.g.
AuthenticationManager.Current.AddCredential(cred);
Mike
GrantHaynes
Thanks, that cleared up the 403 error but now it comes back with a "\"invalid call with current token type\" error, error code 6001
MichaelBranscomb
Looking at the runtime error codes topic, that error code suggests the data returned is not the expected content for a service featuretable.
If you inspect _envWorkingData.Url is it a valid .../FeatureServer endpoint?
GrantHaynes
The resulting URI takes me here ArcGIS Portal Directory so that to me doesn't look like a valid endpoint, but it is consistent with this resource explaining how to add data Access portal content—ArcGIS Runtime SDK for .NET | ArcGIS for Developers.  Maybe it has to do with loading the data? I followed the guide here on how to that  Features and graphics—ArcGIS Runtime SDK for .NET | ArcGIS for Developers
MichaelBranscomb
Sorry - I should have spotted this sooner - the property you want is PortalItem.ServiceUrl Property rather than PortalItem.Url.
Mike
GrantHaynes
That was it. Thanks!
