Integer - auto insert comma for thousands separator
2161
04-05-2020 07:29 AM
KatrinaHigh
I am using Survey123 Connect to create a survey. Is there a way to set up the survey to automatically insert a comma for an integer? For example, 5,000 instead of 5000 or 150,000 instead of 150000.
JamesTedrick
Esri Esteemed Contributor
Hi Katrina,
It sounds like you are wanting to insert grouping separators (which can vary from country to country).  These are supported with decimal questions when using the thousands-sep appearance.
PrachiPatel
Is there a way to use it on integers?
SabineKrier
Is there? I am also wondering why this doesn't work for an integer field type.
