Cannot edit ArcMap
2548
5
03-28-2020 03:54 PM
UmitGunes
I have a score field in the attribute table. I can not edit its value although I can edit the rest of all filed. I couldn't find its reason.
Also, I cannot delete the field although I can delete the rest of all filed
Thank you
UriGilad_EsriAu
Would you be able to share the feature class?
UmitGunes
Hi Uri Gilad
Thank you very much.
Is it enough to share just the SHP file? If yes, I send it to you attached.
Thank you
UriGilad_EsriAu
Hi Umit, the shp cannot be opened on it's own. You'll have to attach the complete shapefile (e.g. shp, dbf, sbx, etc.), or a geodatabase with a feature class.
UmitGunes
I made rar whole folder attached. I hope it works for you.
Thank you
UriGilad_EsriAu
There are no problems when I open the file on my ArcMap. I can edit and delete the Score field:
Some possible solutions:
1. Try to delete/change the field on the rar file you've sent me. If it works then your original file might be corrupted.
2. Did you join fields before you tried to delete/change? If yes this might have to do with a joined field not responding to your editing because it was actually not a part of the feature class.
3. Try to open the feature class in a new project and test.
4. Are you reading it from an SDE? If yes try to export to local and then edit. If it works then it's a lock issue on your SDE.
