Publish python script
2155
5
03-26-2020 11:56 AM
jaykapalczynski
Honored Contributor
not sure if this is the best forum for this question as it leaves the python realm a bit....
I have a python script that does some stuff
    * this runs fine in the editor
I then create a toolbox tool and point it to the python script
    * i can double click the toolbox enter the parameters and run this with no issues
I then publish this to ArcGIS Server after running it
I then go to Server and launch the service and enter the parameters....
it fails....
Anyone have any thoughts on what I should check?  Cant seem to narrow this down
DanPatterson_Retired
did you go through authoring, publishing and using... python scripts beginning in this section.
ArcGIS Pro help, modify if needed
Authoring geoprocessing services with Python scripts—ArcGIS Pro | Documentation
jaykapalczynski
Honored Contributor
This is where I am blowing up......cant figure it out
I am trying to use an SDE connection file that I copied to a location on my server...
This works when I run from the GP tool on the server, but fails when I run it after publishing....
arcpy.MakeFeatureLayer_management('C:/Work/CountySelection/connection.sde/Counties_1_Dissolved', 'counties_lyr')
arcpy.MakeFeatureLayer_management('C:/Work/CountySelection/connection.sde/Buffer_1', 'buffer_lyr')
results = arcpy.SelectLayerByLocation_management('counties_lyr', 'INTERSECT', 'buffer_lyr')‍‍‍‍‍‍
errors would help
jaykapalczynski
Honored Contributor
descriptive errors from ESRI...hahahaah
this is all I get when trying to run from the RestEP
but works fine from the GP Tool itself
DavidPike
MVP Notable Contributor
Perhaps copy the connection file to the server with a full path, have you set up setparameter etc as derived output?
On publishing you should be able to specify the level of error messaging.
