Python String Format using a placeholder
4493
03-24-2020 04:33 PM
NataliaGutierrez1
import arcpy
arcpy.env.workspace = r"D:\APRX_MXDS\USA_Parcels_2019_Project\Test.gdb"
List_dissolve_fc = arcpy.ListFeatureClasses("*Dissolve")  # get a list of feature classes that end with "Dissolve"
fields = ["CO_NO", "COUNTY_NAME"]  # List of fields in test.gdb
for fc in List_dissolve_fc:  # Loop through each feature class in the list
    with arcpy.da.UpdateCursor(fc, fields) as cursor: # Loop through each feature
        for row in cursor:
            row[1] = "{[-17]}".format(fc) # Update each feature in field [1] "COUNTY_NAME" using the name of the feature class without the last 17 characters. For example: walton_2019pin_Dissolve would be walton.
            cursor.updateRow(row)
I need to loop through feature classes and in each feature class I need to update the field "COUNTY_NAME" with the name of the feature class. The problem is, that the name of the feature class is too long and I don't need to include the last 17 characters.
For example: "walton_2019pin_Dissolve" is the name of one feature class and I only want to use "walton" in the field names.
As you can see in the script this is written in line 12.
This method is not working.
How could I do this?
Thank you,
Natalia
JoshuaBixby
MVP Esteemed Contributor
Try:
row[1] = "{}".format(fc[:-17])
JoshuaBixby
Try:
NataliaGutierrez1
Thank you so much Joshua! It worked!
JoeBorgione
While Joshua Bixby‌`s suggestion is spot on, in fact I credit him for showing me how to use format(), I've been trying to use python f strings described here:  https://realpython.com/python-f-strings/ .
NataliaGutierrez1
Than you Joe for sharing the link. There's very good info.
