Shapefile failing to add on map layer
1491
03-23-2020 08:03 AM
MichianaLandServices
I am trying to add a shapefile zipped folder on 4.1MB for landowner data from Defiance county Ohio. I get a message that unable to import.
Robert_LeClair
Esri Esteemed Contributor
Michiana - let's try a different approach.  Go to Content in the top ribbon->My Content->Add Item->From your computer, select the zipped shapefile, Add Item.  If successful, this will create a hosted feature layer.  Then you can click "Open in Map Viewer" to see the layer in a web map.  What is the result?  Please advise.
Dear Robert
I am able to upload the hosted layer, howver when I open in mapviewer it is sending me locations that are way out of Defiance County Ohio.
It is showing layers from Cameroon.
But I know the data is from Defiance county Ohio and I can verify that in mapshapper as in the second image below.
