Using arcpy to create slope surfaces
4407
12
03-19-2020 08:58 AM
JoeBorgione
ArcGIS Pro 2.5
I have a number of .tif  and ,img images that I need to convert into slope surfaces (as discussed here Display A Slope Raster ) and have  been following the steps shown here:  Slope—Help | Documentation .
However, I get one of two errors depending on where I send the slope.save() to.  Here is my script:
import arcpy
from arcpy.sa import *
import os
inDir = r'C:\JoesStuff\SouthernImages'
#outWS = r'C:\JoesStuff\SouthernImages\SlopeRasters' # to a folder
outWS = r'C:\JoesStuff\SouthernImages\Rasters.gdb'  # to a gdb
for i in os.listdir(inDir):
    if i.endswith('.tif') or i.endswith('.img'):
        inRaster = os.path.join(inDir,i)
        outFile = i.split('.')[0]
        outRaster = f'{outWS}\{outFile}Slope'
        outMeasurement = 'PERCENT_RISE'
        zFactor = 1
        method = 'PLANAR'
        zUnit = 'METER'
    outSlope = Slope(inRaster, outMeasurement, zFactor, method, zUnit)
    outSlope.save(outRaster)
with line 6 commented and line 7 active this error is returned:
RuntimeError: ERROR 010240: Could not save raster dataset to
C:\JoesStuff\SouthernImages\Rasters.gdb\12TVK1276Slope with output format FGDBR.
if I try to save the slope to a directory by executing line 6 with line 7 commented  this error is returned
C:\JoesStuff\SouthernImages\SlopeRasters\12TVK1276Slope with output format GRID.
I know the slope surfaces are being created, because when I comment line 20, and replace it with a print statement, the loop runs just fine.  I have run tool manually and it works just great on individual input .tif or .img.
DanPatterson_Retired
the other thread isn't closed
*.tif is the preferred raster format, so the destination of the raster should be a compliant folder path
JoeBorgione
As mentioned, when I run the tool manually, all is good:
Note the values used by default in the symbology:  I'm not sure what was going on when I created the slope surfaces mentioned in the other thread getting the values that were nonsensical (to me).  These values are what I expect:
Looks like DansSlope is a good ol' FGDBR type, right?
*tif is all I use for rasters, I don't even use esri grids anymore and the last thing I would want is for my work to be tied up in a fgdb if I had to use it somewhere else that can't read fgdb .  With *.tif, I can look at in image software, process it in python, numpy etc.  even esri recommends tif (buried in the help,).
symbology is after the fact.
JoeBorgione
Let me give that a try: slope.save(C:\path\to\DansSlope.tif), right?
the reason the "grid" format failed... you can't have esri grids begin with a number
SteveLynch
...and a "grid" name cannot exceed 13 characters.
JoeBorgione
Okay: got it wired using both of your suggestions.  Here's the final script
import arcpy
import os
imageList = ['C:\\JoesStuff\\SouthernImages\\12TVK1276.tif',
 'C:\\JoesStuff\\SouthernImages\\12TVK1474.tif',
 'C:\\JoesStuff\\SouthernImages\\12TVK1476.tif',
 'C:\\JoesStuff\\SouthernImages\\12TVK1674.tif',
 'C:\\JoesStuff\\SouthernImages\\12TVK1676.tif',
 'C:\\JoesStuff\\SouthernImages\\12TVK1874.tif',
 'C:\\JoesStuff\\SouthernImages\\12TVK1876.tif',
 'C:\\JoesStuff\\SouthernImages\\12TVK1877.tif',
 'C:\\JoesStuff\\SouthernImages\\12TVK1976.tif',
 'C:\\JoesStuff\\SouthernImages\\12TVK1977.tif',
 'C:\\JoesStuff\\SouthernImages\\hh12TVK1200076000.img',
 'C:\\JoesStuff\\SouthernImages\\hh12TVK1200078000.img',
 'C:\\JoesStuff\\SouthernImages\\hh12TVK1400076000.img',
 'C:\\JoesStuff\\SouthernImages\\hh12TVK1400078000.img',
 'C:\\JoesStuff\\SouthernImages\\hh12TVK1600076000.img',
 'C:\\JoesStuff\\SouthernImages\\hh12TVK1600078000.img',
 'C:\\JoesStuff\\SouthernImages\\hh12TVK1800074000.img',
 'C:\\JoesStuff\\SouthernImages\\hh12TVK1800076000.img',
 'C:\\JoesStuff\\SouthernImages\\hh12TVK1800078000.img']
for i in enumerate(imageList):
    inRaster = i[1]
    outName = f'Slope{i[0]}'  # f'Slope{i[0]}.tif'
    outRaster = f'{outWS}\{outName}'
    zFactor = 1
    method = 'PLANAR'
    zUnit = 'METER'
I read an article earlier today suggesting enumerate() instead of range() in a for loop and went that route. Line 33
can go to an FGDB grid or TIF image depending on which line (6 or 7) is executed.
So in essence you both answered my question so I'll let you duke it out for bragging rights and just assign it 'Assumed Answered'...
In anticipation of your next question....
Then I suppose I shouldn't tell you what happens if you do the spyder 4.1 update and let you figure it out on your own
JoeBorgione
Actually the laptop I'm using has spyder 3.3 on it since I just went with what ships with Pro 2.5; remember I'm home  practicing good social distancing.  My desktop back at the office has a spyder 3.3 env as well as spyder 4.0 env; I have some packages I use that would have downgraded the 4.0 env so now I have two.  Sounds like I may have three once I'm back there.....
(you're not even gonna give me a hint?)
