How can I create a preview of a data set from the arcpy command line?
627
03-19-2020 07:44 AM
NathanPavlovic2
I am creating a command line tool using arcpy, and I would like to be able to create a simple data set preview from the command line. How can I create such a map?
Tags (1)
JakeSkinner
Esri Esteemed Contributor
Hi Nathan,
I believe the only environment you can do this in would be the Jupyter Notebook.  See the section Display the Web Map in the below link:
Working with web maps and web scenes | ArcGIS for Developers
