Web App Builder 7.4\2.15: Is there an export\download tool?
635
03-17-2020 12:20 AM
JamalNUMAN
Legendary Contributor
I couldn’t figure out if there is an export\download tool
Jamal Numan
MajdoleenO_A__Awadallah
Occasional Contributor III
I tried one option in the past, you need to publish the extract layer tool (the one that we used for geocortex workflow) as a geoprocessing tool, then  Enter the URL of a geoprocessing service as shown
JamalNUMAN
But why there is no way to publish the tools on cloud (ArcGIS Online), Majdoleen?
Jamal Numan
It seems that this option is not available yet, i tried it and end with the same error appear on your screenshot, but why not to try it using portal for arcgis on your machine and try to build the WAB on the portal and consume the service, I will try this myself and get back to you.
Best
You can publish the geoprossing tool to Arcgis server following the steps below after run the tool successfully:
 1. Make sure that the Arcgis server connection is set to administration connection as shown below:
2. Right click on the server connection and select publish the geoprossing tool as shown:
Best
Majdoleen
