Is it possible to have multiple map series in the same layout in ArcGIS Pro?
2343
03-10-2020 08:44 AM
HarrisonMcNeil
I am working on a 25 mile long water line so the exhibits will have a very narrow width but long linear extent. I want to set up my layout to have three alternating map series page number so that when I export the layout series I have three sequential extents of focus on the same page. For example the first page from the layout series would have map series pages 1, 2 and 3, the second layout 4,5 and 6 and so on and so forth.
Any suggestions?
Tags (1)
AdrianWelsh
MVP Honored Contributor
I have this exact same issue!
Harrison McNeil‌ did you find a solution for this?
MarcelSt-Germain
Still ask for the same problem.  Esri always make a layout data driven, mapseries solution and can't understand us with the need of a real mapseries where the extend, rotation, scale are for the maps, not the layout.
Nobody at ESRI understand cartographers needs.
wayfaringrob
Honored Contributor
All, I found an idea related to multi-map map series here: Use Multiple Map Series in Single Layout - Esri Community
Go like it!
