Dataset that has multiple cities within a single cell
509
03-09-2020 10:45 AM
DannyShapich
I have a dataset that has multiple cities within a single cell (separated by pipes, colons, and commas).  Example: Suwon;South Korea;Asia|Seoul;South Korea;Asia
What can I use to separate those cities into different rows (along with the associated data) so that ArcGIS Pro can utilize it?
Tags (1)
DanPatterson_Retired
are there other data associated with each row? or is that it?
DannyShapich
Yes there is data in other columns that would need to be copied to the rows (with separate cities).
Dan Shapich | Programmer/Analyst
Global Programs
316 Boucke Building
The Pennsylvania State University
University Park, PA 16802
Email: dms139@psu.edu
Phone: 814-865-2435
DannyShapich
Here is an example:
University of Leeds Leeds;United Kingdom;Europe|London;United Kingdom;Europe
I would require:
University of Leeds London
I hope that helps.
Global Programs
316 Boucke Building
Phone: 814-865-2435
can you post table (dbf or gdb, csv or excel sheet) with a couple of rows.
It is easy to do with python and numpy using TableToNumPyArray and processing the array.
You have to repeat the number of cities by an unknown amount.
parsing the cities isn't a real problem, setting up the repeats needs to be tested unless you know that there will always be 2 cities, no more, no less.
 a = np.asarray([["University of Leeds", "Leeds;United Kingdom;Europe|London;United Kingdom;Europe"]])
[i.split(";")[0] for i in a[0][1].split("|")]
['Leeds', 'London']
