Fade back map outside of polygon
3538
5
03-04-2020 11:50 PM
rsharma
I have a simple map with polygons on graphics layer, i need to  fade map outside that polygon and show polygon as a hole in the map. I get some relative answer in older version, but it is not helpful.
I want to show like this image
My code is below
<script>
       require(["esri/views/MapView",
      "esri/WebMap",
      "esri/Graphic",
      "esri/layers/GraphicsLayer",
      "esri/geometry/Polygon",
      "esri/geometry/SpatialReference"
    ], function (MapView, WebMap, Graphic, GraphicsLayer, Polygon, SpatialReference) {
         let validSymbol,
          newDevelopmentGraphic;
         * Creates a new WebMap instance. A WebMap must reference
         * a PortalItem ID that represents a WebMap saved to
         * arcgis.com or an on-premise portal.
         * To load a WebMap from an on-premise portal, set the portal
         * url with esriConfig.portalUrl.
        var webmap = new WebMap({
          portalItem: {
            // autocasts as new PortalItem()
         * Set the WebMap instance to the map property in a MapView.
        var view = new MapView({
          map: webmap,
          container: "viewDiv",
          center: ['<?=$map_xy_coordinate['x']?>', '<?=$map_xy_coordinate['y']?>'],
          zoom: 15
        var graphicsLayer = new GraphicsLayer();
        webmap.add(graphicsLayer);
        view.when(function() {
          // Add the boundary polygon and new lot polygon graphics
          addGraphics();
      function addGraphics() {
          //pass geographic vertices
          const vertices = <?php echo json_encode($map_ring_coordinate);?>;
          const polygon = createGeometry(vertices);
          //console.log(polygon);
          validSymbol = createSymbol([0, 170, 255, 0.2], "solid", 2, [
            255,
            255,
            255
          newDevelopmentGraphic = new Graphic({
            geometry: polygon,
            symbol: validSymbol,
            attributes: {
            newDevelopment: "new store"
          graphicsLayer.addMany([newDevelopmentGraphic]);
        function createGeometry(vertices) {
          return new Polygon({
            rings: vertices,
            spatialReference: new SpatialReference({wkid:4326})
        function createSymbol(color, style, width, outlineColor) {
          return {
            type: "simple-fill",
            style: style,
            color: color,
            outline: {
              color: outlineColor,
              width: width
    </script>
RobertScheitlin__GISP
Rajni,
   You can do something like this:
        graphicsLayer.add(newDevelopmentGraphic);
        var mapExtent = view.extent.expand(9);
        var overlayGeom = geometryEngine.difference(mapExtent, newDevelopmentGraphic.geometry);
        var symbol2 = {
          style: "solid",
          color: [129, 129, 129, 0.8],
          outline: {
            color: [255, 255, 255, 0],
            width: 0
        overLayGra = new Graphic({
          geometry: overlayGeom,
          symbol: symbol2
        graphicsLayer.add(overLayGra);
But you would have to figure out how to update the overlay when the newDevelopmentGraphic is being moved or reshaped. I don't have any input on this since I do not think this is a good workflow. Of course you will have to add geometryEngine to your apps require array.
Rajni,
What relative answer in older version. A link would help. And why is it not helpful?
rsharma
I find this link and it uses shape files that i don't use, and couldn't understand how to do it
Rajni,
        var symbol2 = {
          style: "solid",
          outline: {
            width: 0
          symbol: symbol2
rsharma
Its not working, It only show overlay on whole map.
like this my polygon also covered with overlay
This is my code:
          validSymbol = createSymbol([255, 121, 25, 0.0], "solid", 2, [
           255, 121, 25
            geometry: polygon,
            attributes: {
        var symbol2 = {
          style: "solid",
          color: [129, 129, 129, 0.5],
          outline: {
            width: 0
          symbol: symbol2
I don't want to move and reshape the graphics so their is no need to think of it
Rajni,
  Works fine for me. Compare the code to find your mistake.
<!DOCTYPE html>
<html>
<head>
  <meta charset="utf-8" />
  <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no" />
  <title>Intro to MapView - Create a 2D map - 4.14</title>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
  </style>
  <link rel="stylesheet" href="https://js.arcgis.com/4.14/esri/themes/light/main.css" />
  <script src="https://js.arcgis.com/4.14/"></script>
  <script>
      "esri/WebMap",
      "esri/Graphic",
      "esri/widgets/Sketch/SketchViewModel",
      "esri/geometry/SpatialReference",
      "esri/geometry/support/webMercatorUtils",
      "esri/geometry/geometryEngine"
    ], function (MapView, WebMap, Graphic, GraphicsLayer, SketchViewModel, Polygon, SpatialReference, webMercatorUtils, geometryEngine) {
      let sketchViewModel,
        validSymbol,
        newDevelopmentGraphic,
        overLayGra;
        portalItem: {
        map: webmap,
        center: [175.9258624, -37.55590445],
        zoom: 20
      setUpGraphicClickHandler();
      view.when(function () {
        addGraphics();
        // Create a new instance of sketchViewModel
        sketchViewModel = new SketchViewModel({
          view: view,
          layer: graphicsLayer,
          updateOnGraphicClick: false,
          defaultUpdateOptions: {
            // set the default options for the update operations
            toggleToolOnClick: false // only reshape operation will be enabled
        // Listen to sketchViewModel's update event to do
        // graphic reshape or move validation
        sketchViewModel.on(["update", "undo", "redo"], onGraphicUpdate);
        sketchViewModel.update([newDevelopmentGraphic], {tool: "reshape"});
      function onGraphicUpdate(event) {
        // get the graphic as it is being updated
        const graphic = event.graphics[0];
        // check if the update event's the toolEventInfo.type is move-stop or reshape-stop
        // then it means user finished moving or reshaping the graphic, call complete method.
        // this will change update event state to complete and we will check the validity of the graphic location.
        if (
          event.toolEventInfo &&
          (event.toolEventInfo.type === "move-stop" ||
            event.toolEventInfo.type === "reshape-stop")
          sketchViewModel.complete();
        } else if (event.state === "cancel" || event.state === "complete") {
          // graphic moving or reshaping has been completed or cancelled
          // if the graphic is in an illegal spot, call sketchviewmodel's update method again
          // giving user a chance to correct the location of the graphic
          sketchViewModel.update([graphic], {
            tool: "reshape"
        } else {
          graphic.symbol = validSymbol;
      // This function is called when a user clicks on the view.
      function setUpGraphicClickHandler() {
        view.on("click", function (event) {
          // check if the sketch's state active if it is then that means
          // the graphic is already being updated, no action required.
          if (sketchViewModel.state === "active") {
            return;
          view.hitTest(event).then(function (response) {
            var results = response.results;
            // Check if the new development graphic was clicked and pass
            // the graphic to sketchViewModel.update() with reshape tool.
            //console.log(results);
            results.forEach(function (result) {
              console.log(result.mapPoint);
              if (
                result.graphic.layer === sketchViewModel.layer &&
                result.graphic.attributes &&
                result.graphic.attributes.newDevelopment
                sketchViewModel.update([result.graphic], {
                  tool: "reshape"
        const vertices = [
          [175.9258630667, -37.55587745],
          [175.9258671333, -37.5557153],
          [175.92626316670004, -37.5557216],
          [175.92625955, -37.5558657],
          [175.9262584333, -37.5559107333],
        validSymbol = createSymbol([255, 255, 255, 0.3], "solid", 2, [
          255,121,5]);
          geometry: webMercatorUtils.geographicToWebMercator(polygon),
          attributes: {
        var symbol2 = {
          style: "solid",
          outline: {
            width: 0
          symbol: symbol2
          rings: vertices,
            wkid: 4326
        return {
          style: style,
          color: color,
          outline: {
            width: width,
            style: "dash"
  </script>
</head>
<body>
  <div id="viewDiv"></div>
</body>
</html>
