Display KML Data
1511
03-06-2020 04:36 AM
AlexanderLippling
how can I display KML data (from a String/Byte[]/Stream) in a map?
I found examples to load KML data from an URL or file, but I want to do it in memory without network access.
Alexander
DominiqueBroux
Esri Frequent Contributor
There is no direct API allowing to create a KML dataset or a KML layer from a stream. You have to create a temporary file from your stream and to create the KML dataset/layer from this file.
