Smart Editor with Attribute Change not Saved and Symbolizing Correctly
1683
03-04-2020 11:44 AM
BrianKaplan
This problem is demonstrated with two polygons with either a value of Yes or No.  Yes is visualized as green and No visualized as red.  When I change the values in the web map, the polygons change colors instantly.  When I change the colors in a Web AppBuilder for ArcGIS, the colors do not always change.  If I zoom in and out, they may change or may not which corresponds to Yes and No value seeming to have a different value at each zoom level.  See attached.
Repeating myself, if I just use the web map, it works fine.
I created the same data, web map, and web app on a different AGOL organization account and it works fine there.  What could be going on?
AlixVezina
Hi Brian Kaplan‌,
Thank you for reaching out. This looks like it may be related to some caching issues. Please try clearing your browser cache, and if you are still experiencing issues, I would recommend contacting Esri Technical Support to further investigate.
Regards,
Alix
BrianKaplan
Thanks.  I give it a try the next time I work on it.
