X-Esri-Authorization header
1431
03-02-2020 09:55 PM
MuthuVeer
Hi All, i want to hide the token passed as a query parameter in every map request. The Web App Builder application is querying arcgis portal for resources passing the token every time. I need to hide this token from the query parameter. I found that ESRi has suggested to send the token in the X-ESRI-Authorization header instead of as query parameter in the below link
Access ArcGIS token-secured web services—ArcGIS Server Administration (Linux) | Documentation for Ar...
Kindly let me know how to configure the JavaScript application to send the token in the X-ESRI-Authorization header instead of as query parameter.
Muthu
GiacomoFavaron
New Contributor III
Did you find a way? I'm trying to do the same
HariKrishnaInukollu
Hello, Did you find any solution, me too facing the same issue. Can someone please help.
