Return the largest value from a list
1832
02-28-2020 01:35 PM
by Anonymous User
Not applicable
I have a Python script that I am attempting to use to pass the largest value from a list and initialize a counter for sequential ID population.
It has been a long time since I've worked with updatecursors, so please pardon if my code is a bit rusty:
with arcpy.da.SearchCursor(fc, [fldID]) as rows:
myLst = []
for row in rows:
myLst.append(row[0])
intlist = [int(s) for s in myLst if s.isdigit()]
print intlist
highestval= max(intlist)
print int(highestval)
for myVal in myLst:
highestval = counter
counter += 1
with arcpy.da.UpdateCursor(fc, [fldID]) as rows:
for row in rows:
row[0] = prefixName + counter
edit.stopOperation()
edit.stopEditing(True)
del cursor
The problem is, the ID field is a String and not an integer. an example is wFH0003. I am looking at just grabbing the digits from the string. my max(intlist) is returning an empty value. I want to use this as a script to populate ID's that are null or empty.
Any help would be appreciated.
DanPatterson_Retired
/blogs/dan_patterson/2016/08/14/script-formatting
Now you can get your head around this example
# ---- now some sample data
a = ['a1', 'a100', None, 'a2']
# ---- now the case, especially if you have None
[i[len(i.rstrip('0123456789')):] for i in a if i]
['1', '100', '2']
# ---- if you need integers
[int(i[len(i.rstrip('0123456789')):]) for i in a if i]
[1, 100, 2]‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
# ---- you can obviously lstrip as well‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
And you just take the "max" of the returned list
['1', '100', '2']
JoshuaBixby
MVP Esteemed Contributor
If the prefix, e.g., 'wFH', is the same and the structure is the same, e.g., three letter prefix by padded 4-digit text number; you can simply pass the list to max():
>>> l = ['wFH0003', 'wFH0030', 'wFH0300']
>>> max(l)
'wFH0300'
If the prefix varies and there can be variable padded text numbers, can pass a generator expression to max() to avoid having to create an intermediate list explicitly:
>>> l = ['wFH0003', 'mEF030', 'aBE0000300']
>>> max(int(''.join(filter(str.isdigit, i))) for i in l)
300
by Anonymous User
Not applicable
For now I am using a function to pass the prefix value (getPrefixName).
The code below works, but even if the starting value is 0001, it interprets that as 1, and the next record gets calculated as wFH2 rather than 0002. I don't think it's a requirement for the sequence to be zero-padded, but that's what we would like.
Thanks to you and Dan for your advice!
for fc in arcpy.ListFeatureClasses():
          prefixName = getPrefixName(fc)
          fldSort = 'FACILITYID'
          fldID = 'FACILITYID'
          workspace = arcpy.env.workspace
          edit = arcpy.da.Editor(workspace)
          #builds a list of values, passes to a new list, then converts that new list to int
          myLst = [row[0] for row in arcpy.da.SearchCursor(fc, fldID)]
          strList = [i[len(i.rstrip('0123456789')):] for i in myLst if i]
          intlist= [int(i[len(i.rstrip('0123456789')):]) for i in strList if i]
          #increment ID's using prefix passed from function and value initialized from max function
          edit.startEditing(True, True)
          edit.startOperation()
          with arcpy.da.UpdateCursor(fc, [fldID]) as cursor:
            for row in cursor:
                if row[0] == None:
                 highestval +=1
                 row[0] = prefixName + str(highestval)
                 cursor.updateRow(row)
          #stop editing and remove cursor to prevent locks
          del cursor
strings can be padded,
using your lines of code, 1 and 3,
if you want to represent the integers padded, you can use line 5 but the output is strings
pad_int = ["{:0>4.0f}".format(i) for i in intlist]
pad_int
Out[20]: ['0001', '0100', '0002']
