Formating date fields in ArcGIS Pro Report
3765
5
02-25-2020 06:57 PM
DSIProvince_Nord
I am trying to figure out how to properly set date fields in a report :
Report is based on a hosted feature layer (Portal), open in AGPro and most of the report is working well but in the Details section, I try to add a field element from my feature service, which is a date field, and I am facing several issues 1- Field is from the FS and not from the current date or MapFrame date, so type="date" and type="time" does not work. And formatting the dynamic text (<dyn type="report" property="field-value" field="fin" format="dd/MM/yyyy"/>) doesn't work either. It is like the date field is considered a string-field
Alternatively I could set up an Arcade field returning a string value with date and/or time, but Arcade field seems not supported in Reports. Manually setting expression/expr0 in the dynamic field doesn't print the Arcade value but only the string "expression/expr0".
2- I have a time zone issue : Living in New Caledonia, the time zone is GMT+11. In my feature service, WebMap, web app etc... the time zone is correct, but in the report, it is not supported and every time before 11AM appears as the day before... I noticed in my feature service : Date fields Time Zone: UTC(Daylight Savings Time not supported), it may be related but I don't really know.
3- not related to the date field issue, I set an integer field with prestring, poststring and emptystring parameters (<dyn type="report" property="field-value" field="pr_m" preStr="+ " postStr=" m" emptyStr="..."/>) preStr and postStr work, but emptyStr doesn't work, maybe it works only with string field ?
Any help would be appreciated
TanuHoque
Hi @DSIProvince_Nord,
Could you pls share some screenshots to describe your problems? If you happen to have your web app/map public, that'd be great too.
thanks
Tanu
TanyaBagley-Online
Was this issue ever resolved? If so could you share the resolution? I am having the same issue with my date fields getting messed up from a hosted feature service. It works for a long time and then randomly stops working and it won't export the date properly and shows it as a string field.
TanuHoque
@TanyaBagley-Online
We have been aware of some of those issues and working on fixing them all across the platform incrementally.
I hope this blog might help you - https://www.esri.com/arcgis-blog/products/arcgis-pro/mapping/working-with-agol-feature-services-date...
Arcade is still an issue though. Something must have broken recently. I will remove the bullet point in section B.
Please let me know if you have any question.
TanyaBagley-Online
The issue I am having is not with the time zone it is with date field being displayed as just a number instead of a date now when exporting the report to a pdf. It used to work fine and the date field was actually a date but recently, it now shows up wrong and even though I edit the field properties to make sure it is looking at the correct feature service and the correct field. It won't export showing an actual date?
See attached image
TanuHoque
ah.. sorry I misunderstood. Looks like the attachment didn't come thru. Can you ple reattach?
If you add a dynamic text on a layout to show values from a date field, do you see that works?
