No source attachment found in com.esri.arcgisruntime maven dependency
543
02-26-2020 02:27 AM
ShivamMishra2
pom.xml
<repositories>
<repository>
<id>esri</id>
<name>Geotools repository arcgis-java </name>
<url>https://dl.bintray.com/esri/arcgis/</url>
</repository>
</repositories>
<!-- https://mvnrepository.com/artifact/com.esri.arcgisruntime/arcgis-java -->
<dependency>
<groupId>com.esri.arcgisruntime</groupId>
<artifactId>arcgis-java</artifactId>
<version>100.7.0</version>
</dependency>
ControllerClass:
ServiceFeatureTable featureTable = new ServiceFeatureTable("url");
FeatureLayer featureLayer = new FeatureLayer(featureTable);
I tried all the versions then also not able to get the source file for this.
Tags (1)
by Anonymous User
Not applicable
Hi Shivam Mishra‌,
Have you read through this Get the SDK—ArcGIS Runtime SDK for Java | ArcGIS for Developers  for your project setup ?
That shall worth to use that sample as well. GitHub - Esri/java-maven-starter-project: Starter project for the ArcGIS Runtime SDK for Java with M...
And check whether you have download the package from maven as well.
