How to delete an sde file with Python
1096
02-25-2020 08:47 AM
JoseSanchez
Hello everyone,
How can I delete an sde file located in my scratch space.
prefixOutputWorkspace = r"C:\scratch\....\ConnectionToSQL.sde"
if arcpy.Exists(prefixOutputWorkspace):
          delete this sde conection
Recreate sde connection
JoshuaBixby
MVP Esteemed Contributor
You can always use 15.1. os.remove() — Miscellaneous operating system interfaces — Python 2.7.17 documentation to remove files on the file system.
Or, if you want to stay within ArcPy modules:  Delete—Data Management toolbox | Documentation
Deleting a database connection file does not delete the enterprise database. A database connection file is simply a shortcut to the database.
JoseSanchez
This is what  I did:
if os.path.exists(sdeFile):
    # removing the file using the os.remove() method
    os.remove(sdeFile)
