useing tools with Python
917
03-24-2011 01:41 AM
ManuelBeck
I just started the Spatial Analyst training and got a problem already. I cant start tools in the command line of python. The instruction says "Only tools that are in ArcToolbox can be run from the command line". So, the spatial analyst extension is enabled and the tools work fine in the toolbox, but when I type the tool in the command line he cant find it (for slope e.g. he only finds sys). Do I have to connect Python with my toolbox in some way?
I^ve reinstalled ArcInfo allready (my whole system) but nothing changed.
I hope someone could help.
Greetings
m
DanPatterson_Retired
If you are using version 10 of ArcMap, see the code examples here
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//009z000000v2000000.htm
ManuelBeck
Thanks for the help. I´ve found a free training (Using Python in ArcGIS Desktop 10) ,too. But I totally got no clue about programming and python. Therefore I need some help to find a starting point.
So e.g. I want to slope my input Raster (Elev) into a output (SlpDeg) and the unit is Degree. This is the code from ArcGis10 Help:
import arcpy
from arcpy import env
from arcpy.sa import *
env.workspace = "C:/sapyexamples/data"
outSlope = Slope("elevation", "DEGREE", 0.3043)
outSlope.save("C:/sapyexamples/output/outslope01")
And I modified it this way
import arcpy
env.workspace = "Elev"
outSlope = Slope("elevation", "DEGREE", 0.3043) ???
outSlope.save("SlpDeg")
How to modify the outSlope?
Greetings
m
you need to specify a workspace for the grid to go to
import arcpy
env.workspace = "c:/putYourFolderNameHereAsInTheExample")
outSlope = Slope("Elev","DEGREE", 0.3043)
outSlope.save("c:/putYourFolderNameHereAsInTheExample/SlpDeg")
