Attribute rules causing failures in field calculations
3927
8
02-19-2020 12:11 PM
SamSzotkowski1
I've implemented some attribute rules for a feature class to calculate immediately on insert and update.  I know the rules work because when I manually edit the table, or use arcpy.UpdateCursor() to iterate through the table, the rules are enforced.  The problem comes when I try to use Calculate Field(s) geoprocessing tool I get an Error 999999 and an "Arcade error: Field not found" for a field that definitely exists.  I've attached one of the rules and the error message.  Notably there's no GlobalID listed in the error message despite the fact that all the features have a GlobalID.
Any thoughts why this happens?  For now I'm just disabling attribute rules but I'd like to figure out what's happening. I'm using ArcGIS Pro 2.4.3.
SeanSummers_CC
I have run into a similar problem with Calculate Fields.  I wrote my expression in Arcade but never changed the expression type from Python (it is Python by default).  Once I changed the expression type to Arcade it fixed the problem.  Just a thought of something to check.
HusseinNasser2
Hey Sam
are you still running into this problem? We would like to take a closer look and reproduce in the latest software. Can you send us file gdb of a sample data that repro ? would appreciate it
It is ok to use PYTHON to calculate your expressions because that will eventually trigger an update on the row which will execute the attribute rule.
Hussein
matt_g_g
Did this ever get resolved? I'm experiencing the same issue in Pro v3.2.1.
matt_g_g
Sorry, should have included a bit more info before hitting submit!
If I try to run calculate field from the attribute table I get an error in regard to the attribute rules setup on the table but if I use an update cursor via arcpy.da module then I don't get an error and everything executes as expected.
LanceKirby2
Any chance you resolved your issue? I'm encountering something very similar in Field Maps. Tagging @HusseinNasser2 if you have any insight.
HusseinNasser2
posted a workaround ,can you try?
LanceKirby2
Hope this helps @matt_g_g. If you have a moment @HusseinNasser2 my issue is a little different.. I can point you over to this thread if you would be willing to offer some advice. https://community.esri.com/t5/arcgis-field-maps-questions/field-maps-constraint-rule-feature-form-ca.... It would be much appreciated!
HusseinNasser2
Can we try the following?
When running python on a class with attribute rules you must specify all the fields required by the attribute rule in the python cursor.
Here is an example
I have a table with three fields a,b, and c.
Field c has an attribute rule return $feature.b * 2. So the rule require fields b and c
Because b and c are required by the attribute rules those fields must by passed to python as follows.
def update_standalone(fields):
    with arcpy.da.UpdateCursor(str(gdb / 'standalone'), fields) as cursor:
        for row in cursor:
            row[0] += 1
            cursor.updateRow(row)
print('Running')
update_standalone(['a', 'b', 'c'])  # Succeeds
# passing only a will fail
# update_standalone(['a'])  # RuntimeError: Failed to evaluate Arcade expression.
# passing only b will also fail
# update_standalone(['b'])  # SystemError: <method 'updateRow' of 'da.UpdateCursor' objects> returned NULL without setting an error
# passing all fileds or the required fields for attribute rules will succeed
# update_standalone(['a', 'b', 'c'])  # Succeeds
# update_standalone(['b', 'c'])  # Succeeds
print('Done')
