Dynamic map service loading slowly
954
02-18-2020 12:46 AM
yockee
I have an issue with published polygonal Map Services. I have around 30 Map services in a single web app (based on JS 4.11). Maximum 10 of these map services will be viewed simultaneously.
I find it slow to display, as each map service has 80K records and 10+ attributes. These map services will be used in some kind of analysis and processing: popup window, driving time, buffering and attribute downloading based on a point chosen.
If I switch to a cached map service, what processing/analysis are affected? what are the limitation of cached map services?
Will popup window still work correctly?
The map services are hosted online and the data are stored on Postgres Geodatabase.
