Checking for null values in a map series attribute
1477
02-17-2020 08:52 AM
Kara_Shindle
So I am trying to convert a data driven pages script from Python 2.7 to map series Python 3.
My original script, I had an attribute that sometimes had a  file path stored in it, and whenever I would get to a specific page in the DDP, I would store the possible row value as a variable, check if it existed, & append it to my PDF if it did.
Original Script:
pageID = parMXD1.dataDrivenPages.getPageIDFromName(UPI)
parMXD1.dataDrivenPages.currentPageID = pageID
finalPDF = os.path.join(folder, UPI) + ".pdf"
parMXD1.dataDrivenPages.exportToPDF(finalPDF, "CURRENT")
#The attribute with possible sketch pathway
comSketch = parMXD1.dataDrivenPages.pageRow.COMMERCIAL_SKETCH
#opens first PRC Page
prc = arcpy.mapping.PDFDocumentOpen(finalPDF)
if os.path.exists(str(comSketch)):
	prc.appendPages(str(comSketch))
prc.saveAndClose()‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Now, in my code for the map series, if the attribute is Null, it is not letting me store that row as a variable & checking to see if it exists.
Current Script:
mxdFile = arcpy.mp.ArcGISProject(mxdPath)
cleanName = name.replace("/", "_")
finalPDF = os.path.join(outFolder, cleanName + ".pdf")
l = mxdFile.listLayouts("Page_1")[0]
if not l.mapSeries is None:
	ms = l.mapSeries
	if ms.enabled:
		ms.currentPageNumber = ms.getPageNumberFromName(name)
		file = os.path.join(outFolder, cleanName)
		ms.exportToPDF(file, "CURRENT", resolution=300)
#Checks for existence of Sketch PDF & appends it to new PDF
		commSketch = ms.pageRow.COMMERCIAL_SKETCH
		if os.path.exists(commSketch):
			pdfDoc = arcpy.mp.PDFDocumentOpen(finalPDF)
			pdfDoc.appendPages(file2)
			pdfDoc.saveAndClose()‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
I have struggled with trying to access via row objects, search cursors, and for loops, and I am not having any luck trying to store that attribute and check for if it is Null or not.
Update:
This is script I am testing to make a function so that I can call it in multiprocessing for creating about 140,000 multi-page PDFs.
import os, sys
import arcpy
def worker(mxdPath, outFolder, name):
	try:
			ms = l.mapSeries
			if ms.enabled:
		l2 = mxdFile.listLayouts("Page_2")[0]
		if not l2.mapSeries is None:
			ms2 = l2.mapSeries
			if ms2.enabled:
				ms2.currentPageNumber = ms.getPageNumberFromName(name)
				pageTwo = cleanName + "t2"
				file2 = os.path.join(outFolder, pageTwo + ".pdf")
				ms2.exportToPDF(file2, "CURRENT", resolution=300)
				os.remove(file2)
	#			ms.refresh()
		resSketch = ms.pageRow.SKETCH
		if os.path.exists(resSketch):
			l3 = mxdFile.listLayouts("Page_3")[0]
			if not l3.mapSeries is None:
				ms3 = l3.mapSeries
				if ms3.enabled:
					ms3.currentPageNumber = ms.getPageNumberFromName(name)
					pageThree = cleanName + "t3"
					file3 = os.path.join(outFolder, pageThree + ".pdf")
					ms3.exportToPDF(file3, "CURRENT", resolution=300)
					pdfDoc.appendPages(file3)
					os.remove(file3)
					del file3, resSketch
		else:
			pass
			pdfDoc.appendPages(str(commSketch))
		else:
			pass
	except arcpy.ExecuteError:
		# Geoprocessor threw an error
		arcpy.AddError(arcpy.GetMessages(2))
		print("Execute Error:", arcpy.ExecuteError)
	except Exception as e:
		tb = sys.exc_info()[2]
		print("Failed at Line %i \n" % tb.tb_lineno)
		print("Error: {} \n".format(e))
	finally:
		del mxdFile, pdfDoc
	return False
DanPatterson_Retired
Not sure which thing you are trying to collect, but you have no "else" statements anywhere.  That is where you would collect the False returns for the if statements on lines 6, 8 and 15.  If any of those conditions are not met, then the script proceeds on as if nothing happens.  If you want to store a False condition, then you need a container to put the result/condition in (eg a list), then you can check those values after
Kara_Shindle
I had stripped most of my else statements out to try and parse down the code, so I apologize if it made it confusing.
I am trying to capture line 13 as a variable to check if it is false or not.  It won't let me set that variable, as it states that it doesn't exist for my records where the attribute is Null.  I need to figure out how to test whether that attribute is Null or not.
I think what I need is something like:
#store page Row variable Commercial Sketch as commSketch
#if Commercial Sketch exists:
   #append file path to existing PDF
#if Commercial Sketch doesn't exist:
   #do nothing
Whenever my code hits line 13, I get the following error:
Error: 'pageRow' object has no attribute 'COMMERCIAL_SKETCH'
So I haven't figured out how to even get it to the point where it allows me to test if it is False or not.
This is actually part of a function where I am implementing multiprocessing for several thousand PDFs that need created.
I updated my code with the actual function I'm working on
