ElementLayer replacement
1462
02-17-2020 04:26 AM
YaronAvraham
Hi
before migrating to 100.x from 10.2.x there was an ElementLayer that we used to add images (regular bitmap images) to MapView after the migration the ElementLayer disappeared, is there a way to add a layer that displays regular bitmap images?
dotMorten_esri
Esri Notable Contributor
To display geo-referenced images, use either the RasterLayer which is optimized for this (it can even reproject to the right projection), or create a KML Document and add an GroundOverlay node to your KML dataset.
YaronAvraham
the bitmap image is not geo-referenced, it's a regular bitmap image.
YaronAvraham
so is there any way to display Image the is not geo referenced using some type of a layer?
