DBMS error - 42s02 invalid object name invalid for use as a key in an index
4008
6
02-17-2020 01:20 AM
NicolasRoux
Hi everyone !
I try to copy GDB file content (no creator on that source) on SDE GBE. The GDB File is build with relations table. I use "drag and drop" action to copy the files.
The copy was interrupted due to one file (table file) that the type is invalid for uses as a key colomn in an index (abstract of the error message 😉 ).
This file is set up with a key column built like 1111111-1/1 (varchar) and wide as 8000 characters.
I think that :
1- the key column is not right.
2- The field is too wide for the transaction.
Am I right or not ?
Thanks for reading and answering !
Nicolas
WilliamCraft
If the field is a VARCHAR, then you can have up to 8000 characters.  Check to see if the column definition uses VARCHAR(MAX).  If it does, try using a limited size rather than MAX.  What version of SQL Server are you using?  There is a limitation in SQL Server (depending on the version) that VARCHAR(MAX) and NVARCHAR(MAX) cannot be used in indices.  Instead, a fixed length must be used to make it eligible for use in the index.
NicolasRoux
Hi William,
The column definition uses VARCHAR(MAX), up to 8000 characters. The SQL Server version is 2016 (don't SP version as well).
WilliamCraft
Change the column definition from VARCHAR(MAX) to something else with a suitable length such as VARCHAR(100).  Let me know if it works after that.
NicolasRoux
After the change, it didn't work. I get the same error message.
WilliamCraft
After making the change, did you close and re-open ArcGIS Desktop?
NicolasRoux
Sorry for my late response... Yes, I did it.
And I asked to the table owner changing the length field.
Thanks for your answers 😉
