Converting from WebMercator to Wgs84
677
02-13-2020 08:05 AM
DanieBester
I have a set of points (drawn polygon) that have the SpatialReferences.WebMercator property. I need to convert these points to SpatialReferences.Wgs84 before saving to a database. Ideally I would just keep the WebMercator setting, but the existing database is using the Wgs84 format.
I am using the GeometryEngine class, but I noticed that once I reload the polygon, it is off by some way. It is in a different location. How can I make sure this conversion is accurate?
public double[] ConvertMercatorToWgs(double lat, double lon)
      MapPoint point = new MapPoint(lon, lat, SpatialReferences.WebMercator);
      //These lines did not influence the results
      //GeographicTransformationStep geoStep = new GeographicTransformationStep(108211);
      //GeographicTransformation geoTransform = new GeographicTransformation(geoStep);
      MapPoint convertedPoint = (MapPoint)GeometryEngine.Project(point, SpatialReferences.Wgs84,);
      return new double[] { convertedPoint.X, convertedPoint.Y };
DanieBester
So as an example, I just drew a polygon with points
-33.9360095288856 18,391141081041, -33,9075206517435 18,390454436898, -33,9303125156119 18,423413355855
After performing the conversion, the points became
-36.1141869553583 18.0832273300021, -36.0798547481093 18.0825746003061, -36.1073205139085 18.113902885547
