Null if Statement in Calculated Field
3325
5
02-13-2020 03:47 AM
ThomasKelly
I have a column in an attribute table that has a mixture of nulls and data. I wish to create a new column that will return a "yes" if there is data in the column being checked and "no" if it is a null. I have tried a variety of python functions but I keep getting an error similar to the below:
ERROR 000539: File "<expression>", line 1
updateValue(1E+21.0)
SyntaxError: invalid syntax
Failed to execute (CalculateField).
I have tried the following :
X = updateValue(!field!)
def updateValue(value):
   if value == None:
   return 'no'
   else: return "yes"
Any help would be most appreciated.
DanPatterson_Retired
/blogs/dan_patterson/2016/08/14/script-formatting
your indentation was wrong and the code block (eg lines 3-6 or 17-20 ) need to be placed in the code section and the expression (line 10 or 24) in the expression line.
Make the field (!some_field!) active, python parser, put in the code in the code block and the expression in its place and run.
Also don't use == None, use ... is None ...
you don't need your extra else since it will bypass to line 6 if value is not None
# for string field
   if value is None:
       return 'no'
   return "yes"
# calling expression
updateValue(!some_field!)
# for numeric field
   if value is None:
       return -999
   return value
updateValue(!some_field!)‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
ThomasKelly
Hi Dan,
Thank you for the response, I have tried both of these and whilst both expressions are valid I am still returning the following for both:
The (!some_field!) is of data type double ...
I cannot understand why the same error is returning, it should be a straightforward process.
Many thanks
Thomas
1e2
100.0
1e2.0
  File "<ipython-input-2-3dea3e3816b2>", line 1
    1e2.0
spot the difference?
ThomasKelly
is it a decimal formatting issue ?
JoshuaBixby
MVP Esteemed Contributor
This question seems to come up in one form or another about every 6 months on GeoNet.  I think it is important to understand what Dan is pointing out.  Additionally, you can use a Python conditional expression to achieve the result while not needing to define a code block:
"NO" if !field! is None else "YES"
