Query Layer: JS 4x - GetElementById
1841
02-12-2020 12:15 PM
by Anonymous User
Not applicable
Hello all,
In this script, can someone please point out where the well-type options for the select tag is getting populated from? I have tried to incorporate this for my own code but I can't seem to get it working.
ArcGIS API for JavaScript Sandbox
Thank you
Tags (1)
Egge-Jan_Pollé
Hi Sravanthi Murali,
        // return an array of unique values in
        // the STATUS2 field of the wells layer
From the comments in the JavaScript code you point to (ArcGIS API for JavaScript Sandbox) I can see that the well-type options for the select tag is populated with unique values from the STATUS2 field of the wells layer, i.e. the portal item with the id: "8af8dc98e75049bda6811b0cdf9450ee":
https://www.arcgis.com/home/item.html?id=8af8dc98e75049bda6811b0cdf9450ee
This Feature Layer (owned and published by the jsapi_team) points to this Layer https://services.arcgis.com/V6ZHFr6zdgNZuVG0/arcgis/rest/services/HarperSumnerOGWells/FeatureServer/...
You can, for example, query this layer for wells where  STATUS2 = 'KCC Fee Fund Plugging'. This will return 23 wells.
Execute this query to see these 23 wells:
Hope this helps to get your own code running 🙂
P.S. If you think this answer is correct, please feel free to mark it as such, as this will earn me a whopping 250 points on GeoNet...
BR,
Egge-Jan
Egge-Jan_Pollé
BR,
Egge-Jan
by Anonymous User
Not applicable
Hello Egge-Jan,
Thank you! I did look into this in detail and it is from the STATUS2 field. Please see screenshot below.
There are no domain or subtypes in the schema of the HarperSummerOGWells layer  I checked in ArcGIS Desktop.
