How to update a Tile Package in AGOL With Python?
1503
02-10-2020 08:26 AM
ThomasColson
Is updating a Tile Package hosted on AGOL with Python even possible? There used to be https://cloudygis.maps.arcgis.com/home/item.html?id=d829e15ca7d840f29b1a1d8d2e8b7ac7  which no longer works due to SSL settings, which even when tell  urllib to ignore the warnings, it still doesn't work. Surely someone has solved this?
ThomasColson
Trying TileSharingDraft—Sharing module | Documentation , and I see
overwriteExistingService
(Read and Write)
Specifies whether an existing service with the same name will be overwritten.
Boolean
in the documentation, but sharing_draft.overwriteExistingService = "True" (and I tried "true") results in
Service name 'GRSM_STORM_TOTAL_PRECIP_TILES' already exists for 'orgid'
Failed to execute (UploadServiceDefinition).
Is the documentation wrong, or is there a bug and you can't use TileSharingDraft—Sharing module | Documentation  to overwrite an existing tile service despite the documentation suggesting otherwise?
DanPatterson_Retired
booleans shouldn't be enclosed in quotes ...  True ... by itself.  If it requires a string, it should be stated as such and would definitely be an error in the documentation. ( True != "true" != "True" )
ThomasColson
Helpful, changed it, BUT, same error:
env—ArcPy classes | Documentation
if it is a script and deleting that type of object is supported
